700r4 wont shift out of 1 works fine in rev 1988 gmc sub
need help it is in 88 gmc sub 2 wheel dr
How does the trans fluid look? Dirty? Smell burnt? Proper level? If all is good, it sounds like it's time for a rebuild.
Steve |
its dirty i was wondering if i changed the filter and fliud if that would help
700r4
does this tranny use vaccum off of card like old turbo 350's i pu a 700r in a 72 model pickup one time and it wouldnt shift out of first because the hose i was using for vacuum was screwed up fixed that worked great
700r4
vaccuum off of carb, i meant
Has the trans been in the truck and working properly for some time, or was it just installed? Any other work just done on truck? Anything done with the throttle body, or throttle cable and detent cable?
Steve |
just installed and spent to much money
I would look closely at the adjustment of the detent cable. Was it a rebuilt unit or a used unit?
Steve |
| 700R4 will not shift into 3rd and 4th gear | bebopwally | Transmission - Rearend | 14 | 05-25-2006 07:48 PM |
| 700r4 no shift!! | MonteCarloDave | Transmission - Rearend | 2 | 07-19-2005 06:05 PM |
| 700r4 won't shift into 3rd????? HELP!!!! | ConvertablePickupGuy | Transmission - Rearend | 7 | 02-14-2004 05:44 AM |
| 700R4 fine one minute, then dead | Ted Bundy | Transmission - Rearend | 0 | 10-23-2003 03:22 PM |
| 700r4 shift rod connection | crshrmn3 | Transmission - Rearend | 0 | 09-15-2003 04:54 PM |
