Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 won't shift out of 1st gear
Old 08-09-2008, 02:29 PM
metalhead2910 metalhead2910 is offline
I've got a 700R4 that i put in exactly one week before it died. Ran fine for the week, but on the last day i noticed it stalled twice, and a slight rpm bogdown in deceleration. The stalling it had done before, bad exhaust leak. Anyhow, after a very light amount of "gunning it" and coming to a stop, it won't shift from 1st gear. It will go into reverse. Also, if i put it in say, 1st or second gear, and try to shift(on the column) into 3rd or Drive, or even neutral, it die's, shakes, and stops. I was low on fluid, but even after replacing the fluid, doens't fix the problem. Possibly governor or clutch pack? Don't know much about transmissions, and any help would be MUCH appreciated!
