Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 won't shift out of 1st gear
Old 08-09-2008, 03:21 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi,
Not shifting out of first could be a stuck throttle valve,
sometimes you can get them unstuck by removing the tv cable
from the linkage at the TB w/the engine running & in park
move the cable in & out very fast a few times, if this doesn't
work then you need to remove the valve body to get it unstuck.
Look at your knock sensor is there a wire on it, that cut wire may be for it.
Rich
