Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 won't shift out of 1st gear
Old 08-09-2008, 06:14 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
The TV cable should pull out and return smoothly with the engine running or not.
It may be a cable problem or you may have an internal problem with the TV assembly inside the valve body.. If there is excessive wear in the TV bore , the valve can be hydraulically applied and held in the "full" applied position..
Have you checked the governor plastic gear yet?
