Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 won't shift out of 1st gear
Old 09-21-2008, 11:08 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi Fred,
The valve body is what your looking at when you drop the pan,
but before you do that make sure the TV valve or cable is not sticking like metalheads was, if that's OK, then take the car for a ride get going around 25 mph & hit the gas peddle a few times HARD, you know hit it hard let it up & repeat do this a few times, if that doesn't free it up then the pan needs to come down, they'll do this for you at a trans shop for about$65.
Good luck,
Rich
http://www.tvmadeez.com/article/index.php
http://www.cpttransmission.com/tech_tvcable.htm
