700R4 won't shift out of 1st gear - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-24-2008, 06:04 PM
700r4 problem
the problem i have i have good torque in reverse low and 2nd but in drive or od its like i have a stall in it and it wont hardly pull. with the engine running and you pull the tv cable manually it will shift 1 time but i have to pull the cable almost all the way.
4l60e First Gear Wont Shift chevy71z Introduce Yourself 5 08-11-2008 10:58 AM
700r4 tranny not shifting out of 1st dmd02769 Transmission - Rearend 3 09-21-2006 09:45 PM
700R4 will not shift into 3rd and 4th gear bebopwally Transmission - Rearend 14 05-25-2006 07:48 PM
Transgo Shift kit "stick mode" 700r4 eliotmansfield Transmission - Rearend 11 05-03-2005 08:22 AM
700r4 shift times is this ok? evltwin Transmission - Rearend 1 04-23-2004 06:22 PM
