700R4 won't shift out of first - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2012, 11:12 PM
Fluid leaking from somewhere, But My dipstick shows its acurrate when i checked it.Putting new filter in to see if there is any metal. How do I check the adjustment on detent cable? 1988 IROC Tuned Port Injection 5.7
Old 02-23-2012, 01:48 PM
327NUT's Avatar
The "TV" cable (throttle valve) look at www.bowtieoverdrives.com, they have a very in depth section on adjusting it........and if you don't do it properly you WILL burn up your trans.
can i use the 700-2-3 Shift Kit with the B&M Shift Improver Kit in my 1985 700r4 84chevyc10 Transmission - Rearend 8 01-16-2012 11:05 AM
700r4 will not down shift 1chevelle Transmission - Rearend 2 07-30-2008 08:27 PM
700R4 doesn't shift right...... flashback Transmission - Rearend 5 07-06-2008 11:41 PM
700R4 won't shift out of first Tim in MD Transmission - Rearend 15 11-29-2007 08:00 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
