Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 wont shift out of first gear
Old 01-01-2009, 11:34 AM
50BLUECHEVY 50BLUECHEVY is offline
Roddin in OK
Last journal entry: Still Moving Forward
TV stuck
Agreed SS , the bad news is if the TV is stuck,you can't tell by the cable.[ a seasoned pro maybe]The cable is hooked to a spring loaded mechanism that stays the same regardless if the TV is stuck.The popping of the cable is just a quick thing you can try before you go more indepth.Also remember that if the valve body is pulled you remove the arm that keeps the tranny in park,so it can slip out and roll.Safty should be a priority
