Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 wont shift out of first gear
Old 01-01-2009, 09:07 PM
illegal regal illegal regal is offline
Originally Posted by 50BLUECHEVY
Agreed SS , the bad news is if the TV is stuck,you can't tell by the cable.[ a seasoned pro maybe]The cable is hooked to a spring loaded mechanism that stays the same regardless if the TV is stuck.The popping of the cable is just a quick thing you can try before you go more indepth.Also remember that if the valve body is pulled you remove the arm that keeps the tranny in park,so it can slip out and roll.Safty should be a priority
OK...I DROPPED THE PAN, THE FLUID IS A DIRTY PURPLE COLOR WITH SILVER SWIRLS BUT NO SHAVINGS AT THE BOTTOM OF THE PAN NORE FILTER. I PUSHED THE LEVER WHERE THE TV CABLE HOOKS AND THE VALVE IS MOVING IN AND OUT, IS THAT WAS SUPPOSE TO BE STUCK? OR DO I HAVE TO DROP THE VALVE BODY?
