700r4 won't shift out of first gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2008, 07:00 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I got a 700r4 in a T Bucket and we were doing a bucnh of burn outs for little kids. It was a very controlled event. SO DON"T GO THERE. anyway doing a lot of burn outs and now it won't shift out of low gear. I have park, reverse and low. put it in drive and it won't shift at all. Tried to manual shift no go either. I pulled the gov out and the little valve inside was stuck so I got a new gov, and put it in, but it did not help. Any ideas what to look at?
Old 07-19-2008, 08:38 PM
Pull the govenor, most likely the plastic gear just gave up. Also ck the drive gear, make sure its locked to the shaft.
Old 07-20-2008, 07:34 AM
RPM's Avatar
RPM RPM is offline
I put a new gov in it. The gear was fine.
Looks like it has to come out.
Old 07-20-2008, 12:11 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Pull the pan first, see if the TV valve is stuck 'in'. The valve behind the aluminum plunger can sometimes stick. This will cause the pressure to be sky high, making the trans think it's WOT.
If the TV linkage is broken, same thing, the TV check ball will seat and the pressure will max out.
It's in the valvebody, shouldn't have to yank the trans.
Old 07-20-2008, 06:57 PM
RPM's Avatar
RPM RPM is offline
OK great thanks for the info I'll check all that. I did not get to work on it today. I did check the cable and it was not broken...
Old 08-16-2008, 07:17 PM
RPM's Avatar
RPM RPM is offline
You were right on the money! a friend came by today that is good with trannys and it was stuck. cleaned it up and it works fine now.
Need Help with 700r4 No 4th Gear Jackson63 Transmission - Rearend 7 04-20-2015 09:45 PM
4l60e First Gear Wont Shift chevy71z Introduce Yourself 5 08-11-2008 10:58 AM
700R4 sticking in 2nd gear chrisape Transmission - Rearend 6 01-04-2007 05:01 PM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
