700r4 wont shift out of first gear - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-07-2009, 12:16 PM
sticking valves
Originally Posted by briscoe
if you have access to a 0-300 psi gauge you should go to mainline tap,above manual linkage,read pressure in park should be about 70 psi with stock pressure regulator spring,if it is up around 90-95 psi suspect stuck tv valve in valve body,quick test,saves you the hassle of pulling gov.also if it is stuck and you pull the pan,to pull the valve body should be very little debris in pan,or dont bother pulling vb,the valve will stick again.if pan is clean,i will give you good advice on how to keep tv valve from sticking,hope this helps
how do i keep my valve from sticking i have the same problem
  #32 (permalink)
Old 02-07-2009, 01:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no you do not.... the quote by briscoe you posted is about the TV valve in the v-body, not shift valves
You have a v-body sticking in up shifted mode = 2nd gear from what you post.
You have some debris that is sticking the governor or the shift valves. Something is causing debris to stick the valves.
If you have replaced the v-body and various other bits... the debris is from the cooler system of the trans, the converter, bushings...
  #33 (permalink)
Old 02-08-2009, 07:15 AM
so in other words give it a good flush? if so can i do it at home cause i know lube shops use a machine that pump new fluids in and old fluids out
  #34 (permalink)
Old 02-08-2009, 07:32 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You need to find out where this debris is coming from..something is sticking the valves inside this transmission. You have gone from Throttle Valve sticking problems to shift valves sticking , along with governor problems.
It sounds like the cooling system for the transmission needs to be cleaned well or replaced. I would disassemble the transmission to clean and check everything.
You have posted about multiple valve body replacements caused by sticking valves. You posted about valve body cleaning along with governor sticking problems.
If the previous transmission trashed up the cooling system , that stuff will wash out with fresh fluid.
Need Help with 700r4 No 4th Gear Jackson63 Transmission - Rearend 7 04-20-2015 09:45 PM
700r4 won't shift out of first gear RPM Transmission - Rearend 5 08-16-2008 07:17 PM
4l60e First Gear Wont Shift chevy71z Introduce Yourself 5 08-11-2008 10:58 AM
700R4 sticking in 2nd gear chrisape Transmission - Rearend 6 01-04-2007 05:01 PM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
