700r4 wont shift out of first gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2008, 09:11 PM
i have a 78 regal fastback. i just swapped out my th350 for the 700r4...it just been built and installed, the first time i drove it...it shifted well...1st...2nd...3rd...and 4th. my line sprung a pin hole leak and put me like a lil over a quart low. i filled it up and now it wont come out of 1st!?! if the t.v cable is still hooked up...what can it be???
Old 12-22-2008, 10:13 PM
SSedan64's Avatar
T.V. Exhaust ball or = binding, mispositioned or unhooked allowing ball to seal causes full T.V. pressure regardless of throttle position. My best guess. Adjust the TV cable & see if it'll shift at WOT/WideOpenThrottle. If so it's probably stuck in default mode. May have done this when the pressure loss from leak happened.
Do Not run with the TV cable unhooked or misadjusted . Can cause low pressure & a burnt trans very quickly. Crosley can help more as I'm no trans expert.
Old 12-23-2008, 06:05 AM
tnsmith10's Avatar
when will it rain???
did u flush the cooler lines during the trans swap? is the 700r4 rebuilt?
another thing that can cause a no upshift condition is a broken or "applecored" govenor gear.
lastly, u mentioned that the car is a buick regal, has a engine swap to a chevy been done? a 700r4 wont bolt up to a buick engine. r u sure its not a 2004r?
Old 12-23-2008, 12:18 PM
O!!! HELLS YES!!! A SBC 400 block stroked 2 a 383!!! some extra goodies in side but not extreme. anyways...but the governor is brand new...
Old 12-23-2008, 04:16 PM
Shifts are controlled by the interaction of the TV valve and governor. If adjustment of the TV cable doesn't restore function, then the options get more complicated and expensive.
Start with checking the TV cable adjustment and the operating fluid level. You need to cycle the tranny thru reverse and drive, then check the fluid level at hot to see where it really is. If these don't do it then you'll have to start with pressure checks, this is where it starts getting complicated for the hobbyist.
Bogie
Old 12-27-2008, 11:55 PM
Roddin in OK
Last journal entry: Still Moving Forward
700 ohh sweet 700
Even if the tv cable is on and adjusted right,the tv valve can be stuck i've seen it alot over the years.Especially when a 700 gets hot or are fresh rebuilds [as a little trash can get in]. popping the cable a couple of times sometimes works or in some cases i've had to remove the valve body and loosen the tv valve, working it in and out.If you have to do this a 700jr. kit is great to install because you get a no stick tv valve with it.
Old 12-31-2008, 12:16 AM
OK...i tried adjusting the t.v cable...now when i drive it, it acks like it dont wanna go into 2nd but wen i get off the throttle it shifts but now no 3rd!!! this is a pain in the rear!!! I HAVE TO PEDAL IT TO GET 2ND AND PRAY FOR 3RD.... whats going on???
Old 12-31-2008, 05:22 AM
tnsmith10's Avatar
did you set the cable where its tight @ WOT or more like the 350? the cable adjustment is very critical on a 700r4.
Old 12-31-2008, 09:39 AM
Roddin in OK
cable adjustment
The adjustment is off.I would get someone who knows how to adjust it to show you how.But like mr. smith said:it's critical so don't drive it like here's a link that shows how. http://www.tvmadeez.com/article/index.php
Old 12-31-2008, 10:30 AM
Sorry, I know you are asking a tranny question but is your motor a 350 storked to a 383(400 crank in a 350) or a 400 DE-stroked to a 377 (350 crank in a 400)?
I worry about someone reading something and get misinformation.
Old 12-31-2008, 04:07 PM
HOW WILL THE TV CABLE FEEL IF THE VALVE IS STUCK OR STICKING?
Old 12-31-2008, 09:30 PM
ITS RETROFITTED SO WILL THE LOCKUP SETUP HAVE ANYTHING TO DO WITH IT?
Old 12-31-2008, 11:19 PM
SSedan64's Avatar
Lockup wont effect the shifting, just whether or not the TCC locks. TV cable will. If the cable is too tight it creates a high pressure situation like when the trans is at WOT depending on throttle valve position. If the TV valve is stuck or sticking it can also cause high or low pressure depending on TV position and cause it to not shift, shift at too high rpm or shift way too early.
Old 01-01-2009, 11:34 AM
Roddin in OK
TV stuck
Agreed SS , the bad news is if the TV is stuck,you can't tell by the cable.[ a seasoned pro maybe]The cable is hooked to a spring loaded mechanism that stays the same regardless if the TV is stuck.The popping of the cable is just a quick thing you can try before you go more indepth.Also remember that if the valve body is pulled you remove the arm that keeps the tranny in park,so it can slip out and roll.Safty should be a priority
Old 01-01-2009, 09:07 PM
OK...I DROPPED THE PAN, THE FLUID IS A DIRTY PURPLE COLOR WITH SILVER SWIRLS BUT NO SHAVINGS AT THE BOTTOM OF THE PAN NORE FILTER. I PUSHED THE LEVER WHERE THE TV CABLE HOOKS AND THE VALVE IS MOVING IN AND OUT, IS THAT WAS SUPPOSE TO BE STUCK? OR DO I HAVE TO DROP THE VALVE BODY?
Need Help with 700r4 No 4th Gear Jackson63 Transmission - Rearend 7 04-20-2015 09:45 PM
700r4 won't shift out of first gear RPM Transmission - Rearend 5 08-16-2008 07:17 PM
4l60e First Gear Wont Shift chevy71z Introduce Yourself 5 08-11-2008 10:58 AM
700R4 sticking in 2nd gear chrisape Transmission - Rearend 6 01-04-2007 05:01 PM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
