Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 won't shift at WOT
Old 02-04-2005, 04:50 AM
Alex99 Alex99 is offline
New Member
trees, I also thought the problem is in the TV system, BUT even if my TV setting would be wrong, at WOT the plunger should be fully buried in the bushing, right?
Thats what it is now. Maybe the starting position is not right but the WOT adjustment is ok.
So the problem is maybe somewhere else. Could a dirty governor screen cause this problem?
I checked the valves in the valvebody for free movement. All were ok.
Any ideas?
Could the B&M plunger bushing cause this problem? Its for high rpm cruising in OD.
