Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 won't shift at WOT
Old 02-05-2005, 04:28 AM
Alex99 Alex99 is offline
New Member
Hey guys,
I just came back from the testdrive with the original TV sleeve.
No Change!
It didn't change the WOT shifting in any way.
I also checked again the shift points at min throttle because the numbers I gave you before were what I thought and not after a testdrive.
Well, 1-2 at 7mph, 2-3 at 15mph, 3-4 at 30mph.
I guess this comes from my heavier than stock inner governor weights.
The governor looks very good with smooth lands and tight gear and head. I didn't change the springs yet. The original springs were very light. Now mediums are in it. The gov. valve is also not sticking.
You pros need to help me with my problem, cause that was it with my transmission knowledge.
