700R4 Z-Pak Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2013, 11:38 PM
I'm installing the Z-Pak in my '92 700R4. I have the 3-4 apply ring stamped with a "7" which is slightly shorter than the one stamped with a "4" which I took out of it. Do I install the #7 apply ring and use the 5 fingered clutch retainer? If I set it up that way, my 3-4 clutch clearance is 0.045", which seems about right. Or should I use the taller #4 apply ring, and leave out the clutch retainer?
Also, my forward clutch clearance seems tight at 0.030". Too tight or okay? Thank a bunch for the info guys.
Old 03-23-2013, 10:51 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would suggest the .045 clearance if that is the question.
Z pak ; typically this kit includes upper and lower pressure plates? As I recall they did ? Bottom plate was a special machined plate. I've not used these Z-pak kits in a few years, I prefer the Alto kits with thicker steel one side plates
Old 03-23-2013, 03:17 PM
Thanks, Crosley. Yes it does include the upper and lower pressure plates.
Bend Pak Lift or another brand MAX18 Garage - Tools 11 10-01-2010 04:14 PM
power pak 305? TRLBLAZR60 Engine 1 05-13-2007 01:50 AM
Can't get even spraying with Omni Pak SactoStan99 Body - Exterior 7 09-15-2006 04:07 PM
clutch pak rh4414 Transmission - Rearend 1 02-03-2006 12:07 AM
Anyone have a Bend Pak lift? AlanTA Garage - Tools 1 09-01-2004 03:03 PM
