-   -   700R4trans (http://www.hotrodders.com/forum/700r4trans-213121.html)
unclescrouge 01-23-2012 12:52 PM
700R4trans
Hi,got a problem with newly rebuilt 700R4 at times it works great other times when I shift to reverse or netural it seems to be stuck in 2 gears at once.When this happens it is also stuck in 4th when in drive.At all times i can go through 1-2-3-4 shift manually but then when I go to reverse nut. stuck...Bob
SSedan64 01-26-2012 12:40 AM
Do a Pressure Check & check TV Cable adjustment.
http://www.jakesperformance.com/TV_C...etup_Info.html
http://www.extremeautomatics.com/techinfo.html
