Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700rd trans cooler
Old 09-17-2006, 07:37 PM
Chazmac Chazmac is offline
Install auxilary cooler after the radiator mounted cooler. Cooler flow is bottom out, top in, at the trans. Follow the bottom line to the radiator (into the bottom out the top), then plumb the aux. cooler (in front of the radiator) from the top radiator cooler line into aux cooler, then back to the trans top fitting.
