-   -   700RR4 TROUBLE (http://www.hotrodders.com/forum/700rr4-trouble-8848.html)
Mrfixmaster 02-28-2002 05:08 AM
700RR4 TROUBLE
I went through my 700r4, and installed a trans go kit(Gil Youngers) When i tried it I have no reverse. Any thoughts?????
Roy Newton- exprotech 02-28-2002 07:32 PM
Does it have all the other gears. I mean does it shift or only have first gear. Does it have low gear or is it taking off in second. ROY
Mrfixmaster 03-01-2002 03:26 AM
I didn't take it out on the road and try all the other gears, didn't want to hurt it any more than it is. Now that you mention it, it could have been taking off in second. All I did was run it up and down the driveway a couple of times.
Mrfixmaster 04-11-2002 05:58 AM
HEY ROY,---IT'S FIXED!!!!! I pulled the tranny and took off the pan to find the low/reverse boost valve out of the pump laying the pan. Washed everything up, re-assembled it, and it all works. I just love it when a plan comes together!!!
