1970 Would be 6lug, is the 85 a 4x4?
Shane |
They do sell conversion axles that convert to the 5"/5 lug pattern for the older 6 lug rear ends - I have them in my '66... They were $120 each from Summit when I bought them.
I'm assuming the 10-bolt is trashed and he's convinced the 12-bolt would be stronger. I'm not so sure it's any better, but it's not my truck.
It'd be a whole lot easier to sell the '70 to somebody who likes the older trucks and use the money to buy a good '73-'81 12-bolt rear end that'll swap in WAY easier. He'll still need a longer driveshaft, since the 8.5" 10-bolt has a slightly longer snout than a 12-bolt. The yokes might not be the same size, so a conversion U-joint might also be required. I got mine at NAPA. Swap the whole brake assemblies from the backing plates out. While the axles are out, put new seals in the housing ends, maybe new bearings, too. Check the axles where the outer bearings ride for grooving, and replace them if necessary. A couple of quarts of gear lube and a new gasket and he'll be good to go with plenty of money left over. Make him give what's left to you for being so helpful. I hosed down the tops of my spring U-bolts with used motor oil about a week before I swapped mine, and they came off much easier than when I first tried one. |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Hoods not shuting all the way | 74_Chevrolet | Body - Exterior | 5 | 09-01-2005 07:10 PM |
| body parts fitting | anyoldchevy | Body - Exterior | 10 | 02-20-2005 09:20 AM |
| Door Alignment | Ron M | Body - Exterior | 2 | 08-21-2004 01:43 AM |
| New 12 bolt rear? | strikingthematch | Transmission - Rearend | 3 | 07-28-2004 11:41 PM |
