70's ford axle swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2008, 06:25 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
70's ford axle swap
i know its not hotrodding but, I have a 79 250 4x4 4 speed dana 44 front dana 60 rear. I want to buy a 74-77 250 for its axles dana 60 front, dana 70 rear 4:11's. I need to know if the axles just " swap in" . Is there anything i must know ie. change u-bolts steering drive shaft's an such.
Thanks again.
billC
Old 03-04-2008, 06:15 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
from what Ive seen you will need everything from the springs down to do a Dana 60 conversion shock brakets & all.
R
"SlowRide66"
"Illegitimis non carborundum"
Ford Econoline or Dodge A100 axle?? wheelsup64 Suspension - Brakes - Steering 4 02-13-2008 07:41 AM
t5 swap on pre '65 ford 289 flamedfordbronco Transmission - Rearend 2 10-25-2005 05:00 PM
i got ford parts on my chevy rear axle roy383ci Hotrodders' Lounge 0 09-11-2005 03:31 PM
striaght 6 swap into a 55 ford truck brett 6868 General Rodding Tech 1 06-11-2004 10:51 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
