Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-22-2007, 10:18 AM
Rough-Rider Rough-Rider is offline
Tyler
71' 350 #7 olds heads on 79' 403 olds
hey guys...i have another question, im wondering what kind of modifications will have to be done to the 350 heads besides drilling the 7/16 bolt holes out to 1/2" to fit on my 403??
thanks for the help!
Old 01-22-2007, 11:37 AM
MRGM MRGM is offline
Im trying to have an idea!
re: 71' 350 #7 olds heads on 79' 403 olds
i beilve that would be it...
You may want to check out www.oldspower.com there are some persons with that same combo, they could probably give very detailed descriptions there.
Old 01-22-2007, 12:51 PM
joe_padavano joe_padavano is offline
Enlarging the head bolt holes will allow you to bolt the heads to the 403, but you may want to install larger valves as well. The #7s came with 1.880" intakes whereas the 403s had 2.000" intakes (which are the low-perf big block valves). While you're at it, you may want to install the larger 1.625" big block exhaust valves as well. The problem is that by cutting the #7s for the larger valves, you'll loose the factory induction-hardened valve seats.
Also, I assume you know that the 403 had big block sized 83cc chambers originally vs. the 68cc chambers on the #7s (which I assume is the reason you're doing the swap).
Old 01-22-2007, 01:44 PM
Tyler
ya i knew the #7 had smaller cc's then the 403 heads...that is why i am making the swap...
thanks for the help!!
Old 01-22-2007, 02:44 PM
baddbob's Avatar
baddbob baddbob is offline
A friend of mine did this last summer, the head bolt holes needed to be drilled, he had larger valves installed, and he needed longer pushrods to make the valvetrain geometry right. Nice bump in compression.
Old 01-22-2007, 04:04 PM
You shouldn't need longer pushrods, since the valve tip installed height should be identical. Unfortunately, most machine shops don't know how to set up Olds heads correctly and chances are the valve tips were set wrong when the heads were machined for the larger valves. The Olds specialty houses sell a tool that allows you to check the valve installed height using the same process as the factory service manual.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "71' 350 #7 olds heads on 79' 403 olds"
olds #5 head johann Engine 1 07-30-2006 10:05 PM
79 trans am camaroking383 Transmission - Rearend 9 07-17-2006 01:35 PM
olds 350 heads for 403? 403_CHEVY Engine 0 06-25-2003 04:57 PM
350 heads on 403 Scorpion Engine 7 01-04-2003 01:02 PM
1968-69 327 1.72/1.5 Heads on 71 350 brennecke Engine 5 04-10-2002 08:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
