Let's move this thread to General Rodding Tech.
Dan
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
hi there
well it depends dealer installed a/c? factory a/c? what engine? dealer and factory installed a/c will be totally different from each other dealer installed will have aftermarket a/c duct vents in the dash and the compressor wont be a harrison black colored one that is so common on GM vehicles if one car has dealer and the other has factory then they wont interchange also the dealer a/c wont have an a/c heater box assembly like harrison factory installed ones are will be the smaller a/c delete heater box, and the a/c lines will run through the firewall, and not through the heater box. ebay, chevy nova forums sites, and craigslist.org are ways to find parts you may need, i should have also if it is the old long style harrison compressor, and sbc engine. good luck |
You could probably make it work, but it won't be easy. To use the factory system on the 71 (that didn't have air when new) would require all of the under dash heater/ AC ducts, dash pad for a AC car, heater core, hole cut into fire wall, different heater/AC controls, control cables plus all of the AC parts under the hood. I think you would need to at least remove the right front fender and inner fender, and hood. It would be a chore.
| Recent General Rodding Tech posts with photos |
| Swapping '73-'77 A-body rear end into a '71, & related questions? | BinderDriver | Transmission - Rearend | 3 | 12-14-2008 01:40 PM |
| Nova Power Steering | crusherdbuzz | Suspension - Brakes - Steering | 9 | 02-27-2007 01:48 AM |
| Will a 390 fit or work in a 73 Mustang..... | onebadmerc | Engine | 4 | 12-08-2005 09:57 AM |
