71 blazer wireing qusetions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2002, 12:31 PM
New Member
Post 71 blazer wireing qusetions
Heres the scoop.. I have the solid brown and brown/white coming off of the ignition. I ran the b/w to run my electric choke. Where does the solind brown wire go? It has very little current.. The b/w wire has 12 volts. I'll just throw these others out their and see if you can help with these as well. Black,green and blue are whats left. No idea about what they are for. Last but not least when I turn the key to the right it fires... No accessory???? Any help would be great..
Old 12-23-2002, 12:39 PM
roys63's Avatar
Post
you need to run the choke wire to the fuse box with a 30 AMP fuse, a switched plug in that powers up when ign is on.
I think the BW wire comes from the starter to give the coil full 12 volts when cranking, you need the power the choke from the ignition switch, or fuse box , you only have about 9 1/2 volts at the coil,
[ December 23, 2002: Message edited by: roys63 ]</p>
