I am pulling the tank in the morning, putting new rubber hoses on top of tank, checking all hard lines from tank to fuel pump, i am going to fix it or buy it P.S. its going to be somthing simple, but your help is as always needed Wormy.
how is the exhaust flow? Ive seen old mufflers come apart and under a loaded acceleration something moves and bbboooooogggggggggg.
If theres any question it may be easier to losen the exhaust flange bolts so it has some room to breath and run it down the road before pulling the fuel tank,or maybe just put a vaccuum gauge on it so you can watch it and take it for a run, if theres an exhaust flow issue you should see your vaccuum drop because if it cant blow it cant suck. just another perspective like you said its probably going to be something simple sometimes you can't see the forest for all the the trees hope this helps GL. P.S. The 71 Buick Skylarkwas not equipped with a wiggling wheel on the wobbling shaft. instead it utilized the kanooter valve in series with the whatchamajig lol Last edited by justacertifiedtech; 07-30-2008 at 11:43 PM. |
Hi Wormy
Check the vacuum advance on the distributor. If the diaphragm is blown, it will run retarded. (retarded). Make sure you have manifold vacuum to it from the ported vacuum switch with the engine warm. |
Car has new set of 2 inch duals, new mufflers, car ran good for 6 months of everyday driving, started acting up a month ago little flutters sometimes, but never when i was in car, he swore something was wrong but if it dont do it when your in car could not diagnose, then it got worse the way it is now, sitting in park it runs like a new car revs good, but soon as it gets a load such as going up a hill it stalls, like it runs out of gas let it catch its breath its good till you put a load on it, thinking it could be a dirty sock filter in tank, if thats not it im stumped. will try vac advance to intake port. more help is needed. Wormy. P.S. Thanks
Wormy, I've had a weak coil produce the same symptoms you're describing. Have you allready tried another coil on it? Had a 66 Skylark that ran fine without a load on the engine, but wouldn't even pull above 15mph in gear then would stall.
Found the problem, the filter in the tank was 90% stopped up with goo, is what it looked like, cleaned tank put in new filter, runs like a charm who would have thought it, must be the well refined gas we have nowadays
anyway thanks for the input. Wormy.
| 40 buick frame same as 40 chev? | powerrodsmike | Suspension - Brakes - Steering | 4 | 03-06-2007 02:17 PM |
| my buick | daddyrain | Engine | 13 | 11-16-2004 10:09 PM |
| '71 Buick I need to find, can you help me? | ChevelleSS_LS6 | Hotrodding Basics | 1 | 10-05-2004 07:52 PM |
| '71 Buick GS 455 stolen! | ChevelleSS_LS6 | Hotrodders' Lounge | 12 | 10-05-2004 06:46 PM |
| Buick Century or Buick Skylark 2 | 7skylark6 | Engine | 4 | 12-26-2003 10:05 PM |
