71 C10 long box to short - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2007, 10:52 PM
71 c10
I just bought a 71 Chev long box. It has a 67 hood and grill on it. still the original front fenders, so they don't line up.
Question #1: My goal is a short bed. Does someone have info on converting this over. I have a good welding shop that works for my business, and I'm sure that they would help me out with the chassis work, as far as welding is concerned. Also, as this project being on a budget, can I use any of the long box parts for my short box, ie. cutting the floor down, front panel... I will have to get new box sides regardless, as the original ones are rough.
Question #2: Will the framework/support system (ie. rad support, fender mounts) be the same on 71 and 67? Can I just buy the 67 front fenders and install? Will the body lines line up on the doors/cowling?
Any help will be greatly appreciated.
Hats off to the guys that are willing to share their knowledge, as well as the moderators for their tireless work on this GREAT SITE.
Thanks in advance
Old 07-08-2007, 07:29 AM
Will I ever get it done?
Last journal entry: Driver's Door
TRUCKS is shortening an early 60's C10. Body style is different, but the frame is basically the same. And the concept of doing it is basically the same. They should re-run the first installment approx. 4 to 5 Sundays from today.
You have to take the largest amount out of the frame under the cab. They did a "Z" cut. They cut half way down the frame vertically, then a horizontal cut the length required to get the wheelbase correct, then the final vertical cut. They did a double butt weld. Then added a rectangular reinforcing plate. The final amount needed to make the frame short enough is obtained by chopping off the rear frame rails the correct amount. You have to move the rear cab mounts back the same amount as the "Z" cut takes out of the frame. They did a very nice job on the show. I would wait until it is on again, tape it, and show it to your welder.
They also had a very clean bed, so they shortened it. If your sides are just beat up, the rest of it can probably be used with new sides. The front panel and tailgate are the same. So are the wheel tubs. Unless your wood is in perfect condition, you will probably want to replace it. It could be cut down. If you have a steel floor, it could be cut down as well. You will have to figure out where the braces need to go. Make sure you have it all lined up before you weld. If the sides are rusty, you better disassemble the box and check the rest of the components real good. Chances are excellent you will need other pieces. LMC has just about everything you need.
According to LMC, the doors are all the same 67-72. So if the hood lines up with the cowl OK, you should be in good shape there.
If you can't wait to watch the show on TV, I think you can buy the video/dvd from the TRUCKSTV web site. The show number is TK2007-10. I can't find a link to buy it, so you might have to e-mail them.
It sounds like you have a very doable and fun project. Post photos of your progress in a journal. That is what I am doing on my 41.
Old 07-08-2007, 10:00 AM
71 c10
Thanks Red.
That gets me started. I am emailing to get the episode on DVD.
I greatly appreciate the help.
Old 07-13-2007, 09:11 AM
joe k's Avatar
Go to 67-72 chevytrucks.com do a search on their site and you will find what you need to know,with pictures.
Old 07-13-2007, 10:50 AM
71 c10
I just found this website:
www.earlyclassic.com/tech.aspx?category=Longbed,%20No!-Shortbed
Old 07-13-2007, 12:00 PM
anyone have a step by step for 73-87s?
Shane
Old 07-14-2007, 08:06 AM
joe k's Avatar
Shane go to 73-87.com, garage section ,has a how to on your year truck.
Old 07-14-2007, 10:51 AM
Thanks
Shane
Old 07-14-2007, 06:28 PM
fast68's Avatar
likes chevy trucks & boobies
72 doors are one year only
72 panels are plastic
72 doors have a phillps head screw on the visible painted part of the upper part of the door just below the vent wing handle location
67-71 dont and instead are steel panel flat and no phillips screw
67 68 fenders and hood and grille and headlight buckets welded to the support are unique to those two years only, or just swap entire support
69-72 changed fenders on chevies(but on gmc kept 67 68 fenders)
69-72 chevy and gmc are flat front hoods,
but gmc had a special spacer piece to allow the 67 68 style fenders to work on the 69-72 hoods
gmc did not change to 69-72 chevy fenders
all 68-72 gmc are 68 chevy fenders which makes them the most abundant and are my favorite of all these six years
all 67 were identical
68-72 markers vs. 67 no markers
cowl panel is same one all years
the only parts that changed were the fenders and hood
bumpers too
since the lights were in the bumper 71 72 but not in 67-70
bototm line is that 67 fenders bolt up to your truck directly as is yes
no problem
you wil have to decide if you want sidemarkers or not right now before you put the bed on/together
67 were no markers
68 were
so what fenders do you want
nows the time to decide
12" needs to come out of the frame rails just behind the cab, and i forgot how many inches off the rail ends
Z-cut is what to do here
dont do it any other way
use a plate inside it too
best way would be to swpa your body on a short chassis
but sometimes you cant find a cheap old shortbed for the frame sitting around abandoned or something
heres a ****** 67 a member on this site owns:
http://hotrodders.com/gallery/showga...0&ppuser=30718
drool!
andi saw one identical to this in bloomington last night rolling down veterans parkway
i about wrecked trying to look at it
i LOVE these trucks, are the best looking and riding GM trucks they ever made BY FAR
if you need any more details lemme know
Old 07-16-2007, 03:28 PM
71 c10
Thanks Fast, I appreciate the help
Long or Short Tube Headers? Ray102386 General Rodding Tech 13 05-12-2011 09:16 AM
Long water pump to short. What's involved? hiimed Engine 4 07-16-2003 07:32 PM
Anyone know where to find a '60-'66 nailhead short or long block??? Ravenous Rod Transmission - Rearend 3 02-05-2003 04:02 PM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 01:53 PM
The long and the short of it. 57Chevyman Engine 2 02-12-2002 10:46 AM
