71 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2005, 07:32 PM
ddwills's Avatar
New Member
71 camaro
Hi all, my 71 camaro wont shut off after i start it . need help.
Old 09-02-2005, 08:21 PM
docvette's Avatar
Wiki Edits: 12
won't stop
Doc here,
Check your wires going to the primary and secondary ignition on the coil..major offender is the wire from the secondary shorted to or touching the main battery cable at the starter solenoid.
If your running an aftermarket ignition..you may need to install a diode on the alternator main power line to cure the problem. you can test it by starting the car up with the alternator unhooked..if it shuts off, you need the diode.
Doc
Old 09-02-2005, 08:49 PM
ddwills's Avatar
New Member
HI Doc, my 71 has a hei on it,whit 2 wire hook up. tahnks for all the help.
Old 09-03-2005, 03:40 AM
docvette's Avatar
Wiki Edits: 12
Doc here
As per our PM...Same applies..check those items out..
Doc.
Can I make my 78 firebird into a Camaro? Suckingas Body - Exterior 9 06-28-2010 11:06 PM
34 pontiac 81 camaro subframe install ? mobythevan Suspension - Brakes - Steering 7 05-19-2005 12:17 PM
71 camaro engine ddwills Engine 1 04-12-2004 07:24 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 11:45 AM
What do you guys think about the second gen camaro neil madsen Hotrodders' Lounge 6 10-30-2002 02:26 PM
