-   -   71 camaro frontclip on a 55 chevy truck? (http://www.hotrodders.com/forum/71-camaro-frontclip-55-chevy-truck-204612.html)
SmokemhontaS 08-31-2011 03:35 AM
:confused: Im new to this forum thing and I'm having troubles with finding out if a 71 camaro front clip would go on easily to my 55 Chevy 1st series truck. Also how much would it drop the front end?
poncho62 08-31-2011 04:45 AM
How much it drops the front is up to you and how you weld it in, how you position the clip.......I did one on my 51 Ford and it dropped it quite a bit.
The thing about this is, you are still going to have a 40 year old front suspension design......Does this 71 clip have disk brakes?......
http://img.photobucket.com/albums/v4...295truck21.jpg
http://img.photobucket.com/albums/v4...1010Medium.jpg
SmokemhontaS 08-31-2011 04:50 AM
Thanks! I will take that in to consideration when the time comes to actually weld it on. I want the most drop i can get put of it, also you have any advice on putting airbags in the stock leaf spring rear suspension? And yes it has disc brakes!:D
NEW INTERIORS 08-31-2011 09:03 AM
4 Attachment(s)
I did a nova front clip on this 58 Chevy truck.... The camaro is a little wide for that truck to me,, The nova worked out very well on this truck..As far as the ride height goes,, That is up to you when you weld it on... The more you zee the frame, The lower it will sit.. This truck has no motor in it and these pictures..
http://www.hotrodders.com/forum/atta...id=58079&stc=1
http://www.hotrodders.com/forum/atta...id=58078&stc=1
http://www.hotrodders.com/forum/atta...id=58076&stc=1
http://www.hotrodders.com/forum/atta...id=58077&stc=1
NEW INTERIORS 08-31-2011 09:12 AM
3 Attachment(s)
This is with the big block in it..
http://www.hotrodders.com/forum/atta...id=58080&stc=1
http://www.hotrodders.com/forum/atta...id=58081&stc=1
http://www.hotrodders.com/forum/atta...id=58082&stc=1
MARTINSR 08-31-2011 10:13 AM
"Easy" that is a VERY subjective term. What would be very easy to someone and do it an afternoon would be unthinkable to someone else.
As frame clips go, this is one that works out pretty well being the frame widths are so close.
SmokemhontaS 08-31-2011 11:45 AM
Maybe i meant to say would it be more dueable and not a headache. And thankss new interiors, so is the Nova frame aclip a better way to go? Is it wider or more narrower than the mustang one?
NEW INTERIORS 08-31-2011 12:54 PM
Anytime.. :thumbup:
The nova clip is narrower then the Camaro... Like about 1.5 ''... As far as the mustang II,,, I'm not sure right off the top of my head....
Also... remember the nova has a rear steering box..
The Camaro has a front steering box..
The Nova worked out great in this truck..This was a 1958.. :thumbup:
The Camaro will work,, You just have to watch when your low to the ground,,, With the wrong tires, you might have trouble turning..
poncho62 08-31-2011 04:26 PM
The Nova change in 74, I believe, to front steer....I used a 76 Nova clip in mine.
shine 08-31-2011 05:25 PM
3 Attachment(s)
they work great under tri5 trucks. i use the whole clip. lowers it about 2 more inches.
