71 camaro frontclip on a 55 chevy truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2011, 03:35 AM
SmokemhontaS's Avatar
Im new to this forum thing and I'm having troubles with finding out if a 71 camaro front clip would go on easily to my 55 Chevy 1st series truck. Also how much would it drop the front end?
Old 08-31-2011, 04:45 AM
poncho62's Avatar
Wiki Edits: 5
How much it drops the front is up to you and how you weld it in, how you position the clip.......I did one on my 51 Ford and it dropped it quite a bit.
The thing about this is, you are still going to have a 40 year old front suspension design......Does this 71 clip have disk brakes?......
Old 08-31-2011, 04:50 AM
Thanks! I will take that in to consideration when the time comes to actually weld it on. I want the most drop i can get put of it, also you have any advice on putting airbags in the stock leaf spring rear suspension? And yes it has disc brakes!
Old 08-31-2011, 09:03 AM
life is a temporary assignment
I did a nova front clip on this 58 Chevy truck.... The camaro is a little wide for that truck to me,, The nova worked out very well on this truck..As far as the ride height goes,, That is up to you when you weld it on... The more you zee the frame, The lower it will sit.. This truck has no motor in it and these pictures..
ID:	58076   Click image for larger version
ID:	58077   Click image for larger version
Name:	all pics 2260.jpg
ID:	58078   Click image for larger version
Name:	all pics 2272.jpg
Old 08-31-2011, 09:12 AM
This is with the big block in it..
ID:	58080   Click image for larger version
ID:	58081   Click image for larger version
Old 08-31-2011, 10:13 AM
"Easy" that is a VERY subjective term. What would be very easy to someone and do it an afternoon would be unthinkable to someone else.
As frame clips go, this is one that works out pretty well being the frame widths are so close.
Old 08-31-2011, 11:45 AM
Maybe i meant to say would it be more dueable and not a headache. And thankss new interiors, so is the Nova frame aclip a better way to go? Is it wider or more narrower than the mustang one?
Old 08-31-2011, 12:54 PM
Anytime..
The nova clip is narrower then the Camaro... Like about 1.5 ''... As far as the mustang II,,, I'm not sure right off the top of my head....
Also... remember the nova has a rear steering box..
The Camaro has a front steering box..
The Nova worked out great in this truck..This was a 1958..
The Camaro will work,, You just have to watch when your low to the ground,,, With the wrong tires, you might have trouble turning..
Old 08-31-2011, 04:26 PM
poncho62's Avatar
Wiki Edits: 5
The Nova change in 74, I believe, to front steer....I used a 76 Nova clip in mine.
Old 08-31-2011, 05:25 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
they work great under tri5 trucks. i use the whole clip. lowers it about 2 more inches.
ID:	58086   Click image for larger version
ID:	58087   Click image for larger version
Name:	frame clip finished.jpg
58 chevy truck camaro subframe oldchevyguy Suspension - Brakes - Steering 0 02-09-2011 05:12 PM
52 1 Ton Chevy Truck / Camaro graft Jackyl666 Suspension - Brakes - Steering 1 06-07-2008 06:31 PM
81 Chevy truck vs. 82-93 Camaro StrokerBoy383 Engine 5 04-12-2008 12:14 PM
Camaro Rearend in '55 Chevy Truck BillCull Hotrodders Site Suggestions and Help 3 02-01-2007 05:33 PM
Frontclip for a 37 Chevy 1/2 Pickup joerg-kali Suspension - Brakes - Steering 4 08-01-2006 07:46 AM
