71 Camaro power steering problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2012, 08:28 AM
Hacksaw's Avatar
BOOMER SOONER
My buddy just bought a 71 Camaro that is 90% restored. It has been setting for awhile but has a new engine, transmission, etc. the power steering doesn't work. He changed the pump with a new one but it still is hard to turn. It's like it is just not getting fluid through the gear box. He jacked it up and turned it lock to lock for 30 min trying to get air out, but acts like its just not responding. Could the gear box have an obstruction? I've never had to deal with this problem before. Thanks
Old 02-23-2012, 12:14 PM
Canzus's Avatar
a red wool sock on his dinger
Sounds like the pressure relief valve is stuck open...
Try this, with the car running, run the steering all the way hard in one direction, does the pump
load up and belt squeal??
Old 02-23-2012, 02:34 PM
Hacksaw's Avatar
BOOMER SOONER
I will be sure and tell him to try that tonight. Is the pressure relief located in the gear box or pump?
Old 02-24-2012, 06:16 PM
Hacksaw's Avatar
BOOMER SOONER
There is no squeel web turned to full lok with engine running
Old 02-24-2012, 11:09 PM
Canzus's Avatar
In the pump, try google for an exploded view...
Old 02-25-2012, 05:26 AM
Hacksaw's Avatar
BOOMER SOONER
Strange how this thing is. It is doing the exact same thing, no power steering, even with the new pump. I guess the new pump could be bad? Should he take it back since its under warrantee and try another one? What if that doesn't help? Then it has to be gear box right?
Old 02-26-2012, 04:52 PM
Try lifting front wheels off the ground and see if it still hard to turn. It could be steering linkage binding if it is unhook on thing at a time and see if it get easier
Old 02-26-2012, 06:08 PM
Hacksaw's Avatar
BOOMER SOONER
Mechanical steering is fine. It just acts like it is a non power steering vehicle. It didn't work with the old pump, and still not working with a new pump.
Power Steering Pump Problems??? eandabailey General Rodding Tech 8 03-19-2011 10:04 AM
Power Steering 69 Camaro? Jeff J Suspension - Brakes - Steering 6 08-09-2010 08:27 PM
67 camaro power steering 67rscamaro Engine 2 03-26-2003 05:12 AM
69 Camaro, power steering? FiefSS Suspension - Brakes - Steering 1 01-03-2003 12:30 PM
power steering problems nick Engine 1 03-13-2002 04:56 AM
