-   -   71 chevelle dash repaiere (http://www.hotrodders.com/forum/71-chevelle-dash-repaiere-200768.html)
race_jr 06-22-2011 09:57 AM
Hell first time here need info if some one can i have a hole in my dash from a guage and want to fix it is there a good way to do this where it won't be able to see it to much THANKS :confused:
race_jr 06-23-2011 06:30 AM
Hello first time here need info if some one can i have a hole in my dash from a guage and want to fix it is there a good way to do this where it won't be able to see it to much THANKS :confused:[/QUOTE]
1ownerT 06-23-2011 10:05 AM
Can you supply any additional info? What part of the dash, is it metal, plastic, is it the pad, etc.
race_jr 06-23-2011 10:24 AM
it's plastic right next to the steering colume 71 chevelle
alittle1 06-23-2011 11:54 AM
I would go with a little JB Weld in the hole, add some plastic or masking tape for backing the hole if it is larger than a pencil eraser, and because the dash is textured, I would dab it with a shop towel (rag) just as it was tacking up. Smooth it down with 100 - 220 grit when dry, using just a corner of the paper and then paint with SEM black trim paint after giving the area a wash with vinyl prep.
MRTS33 06-23-2011 07:49 PM
Try over at Team Chevelle. Check the want-ads over there. They have a world of Chevelleness. :D
1ownerT 06-24-2011 05:43 AM
The above response is a good suggestion, a replacement would give the best results.
To repair the plastic so it can't be seen would be difficult.
