71 chevelle dash repaiere - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2011, 09:57 AM
Hell first time here need info if some one can i have a hole in my dash from a guage and want to fix it is there a good way to do this where it won't be able to see it to much THANKS
Old 06-23-2011, 06:30 AM
Hello first time here need info if some one can i have a hole in my dash from a guage and want to fix it is there a good way to do this where it won't be able to see it to much THANKS [/QUOTE]
Old 06-23-2011, 10:05 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Can you supply any additional info? What part of the dash, is it metal, plastic, is it the pad, etc.
Old 06-23-2011, 10:24 AM
it's plastic right next to the steering colume 71 chevelle
Old 06-23-2011, 11:54 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
I would go with a little JB Weld in the hole, add some plastic or masking tape for backing the hole if it is larger than a pencil eraser, and because the dash is textured, I would dab it with a shop towel (rag) just as it was tacking up. Smooth it down with 100 - 220 grit when dry, using just a corner of the paper and then paint with SEM black trim paint after giving the area a wash with vinyl prep.
Old 06-23-2011, 07:49 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Try over at Team Chevelle. Check the want-ads over there. They have a world of Chevelleness.
Old 06-24-2011, 05:43 AM
1ownerT's Avatar
Wiki Edits: 4
The above response is a good suggestion, a replacement would give the best results.
To repair the plastic so it can't be seen would be difficult.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 04:14 PM
1970 chevelle ss dash pics. Anyone? Hacksaw General Rodding Tech 6 11-20-2009 06:40 AM
72 chevelle ss dash tach wiring mr67gta Electrical 3 06-03-2008 08:53 PM
72 Chevelle Dash Swap RODNEYBARBER Electrical 2 03-08-2007 03:57 PM
