71 Chevelle rear control arm bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2005, 09:13 PM
71 Chevelle rear control arm bushings Pictures Now Here
I finally broke down and replaced the bushings in the rear control arms. I will have to admit that of all the things I have ever done to a car this is the hardest job ever. I made pullers and presses to remove and install them. I also boxed in the lower arms while I was at it. I repainted the lower arms but the upper arms were body color so I left them alone. The last one I pressed in was on the rear end. I just couldnt get it started straight. It kept wanting to cant to the side and stick. I got my micrometer and measured the hole into the rear end and the bushing. I found the hole was .040 smaller than the bushing. Since only the second half of the bushing is in the ear once fully seated I sanded the first part of the bushing down so it was only .020 bigger than the hole. Then it went in straight and fully seated. I think in all I have about 20 hours in the job. The car is way tighter on the rear end now but I didnt nail it to see if the wheel hop was gone. I did take pictures of the ongoing job but havent taken them out of the camera yet. I used Energy Suspension bushing from Summit. I was pleased how well everything was an exact replacement. All this on a 34 year old car.
Old 04-21-2005, 05:40 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
The can be kind of a pain some times.
When you feel like having some more fun, put in the fronts to match. They are a great improvement. If you haven't done the fronts and decide to do them, you have to reuse the sleeves. The first time I did them I fought like crazy to get the new bushings into the old sleeves. What really helped, I picked up some dry ice and put the bushing on ice for ten to fifteen minutes then they slid right in.
Old 04-21-2005, 05:47 PM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
I just did the rear bushings on my camaro and they are almost identical to the 70 to 72 chevelle ones. I fought the first one and then I figured out that your supposed to remove the rubber from the shell before trying to push them in. What a difference.!!!!!!!!! If you get into that again try installing the shells by themselves and then push the rubber bushings in afterward. A little greas on the rubber bushings makes it fairly easy.
Old 04-21-2005, 07:11 PM
I couldnt get the rubber bushings out of the new sleaves. I didnt want to tear them up so I left them in. They all went in ok except for the ones in the rear end ears.
Old 04-23-2005, 09:46 PM
I see the link didnt work. If you want to see the pictures you can go to my home page and click on the album for the rear control arm bushings.
upper control arm axle bushings, remove/install ss396si Transmission - Rearend 1 02-16-2005 05:57 PM
Changing Bushings on control arms JarridL's68C-10 Suspension - Brakes - Steering 7 07-30-2004 09:46 AM
HELP! very stange metal on metal upper bushings on a chevelle, is this factory? younguyw/oldcrap Suspension - Brakes - Steering 3 05-30-2004 05:17 AM
mustang 2 lower control arm bushings nomaddaddy Suspension - Brakes - Steering 1 02-14-2004 12:28 PM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
