71 Chevelle rear control arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2007, 12:08 PM
Red Rocket racing's Avatar
Diesel drag racer
I am looking to upgrade the stock rear control arms on a 71 454 5 speed Chevelle. What do you guys like???
What do reccomend for rear shocks as well???
Thanks in advance for any help.
Old 09-27-2007, 12:54 PM
Any of the tubular arms are equivalent. The thing to watch out for is polyurethane bushings. The A-body rear suspension geometry imparts a twist to the upper arms as the suspension moves. The stock rubber bushings are soft enough to accommodate this twist without problems. Stiff aftermarket arms with polyurethane bushings will bind the suspension, leading to an awful ride. If anything, get the upper arms with a metal monoball on the forward end. This eliminates the binding and provides much better handling control.
Old 09-27-2007, 01:43 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I will second that! The stock arms with rubber bushings in our 94-96 Impala SSs are weaker than the rubber bushings. What ends up happening is the arms crack.
Global West, Hotchkis, and maybe some others make trailing arms with the spherical ends like you need.
Old 09-27-2007, 03:07 PM
Diesel drag racer
I was looking at the Hotchkis ones. Thanks for the input!!
Trust "beaten on" lower control arms or not? TNshadetree Suspension - Brakes - Steering 3 02-21-2006 01:05 PM
71 Chevelle rear control arm bushings 454me Suspension - Brakes - Steering 4 04-23-2005 10:46 PM
67ssdiagram showing how the rear sway bar and control arms connect to frame and rear DeathByGreaser Transmission - Rearend 0 02-08-2003 09:10 PM
GM G-Body Rear Control Arm Boxing Kit? chevy8298 Suspension - Brakes - Steering 1 01-20-2003 10:49 PM
rear lower control arms oldsnut Suspension - Brakes - Steering 3 12-15-2001 10:01 AM
