71' Chevelle starter actuating rod adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2012, 07:09 PM
How do I adjust the actuating rod so my starter switch is making contact?
(lights work, plug at the base of the steering column looks good, good ground)
Old 08-09-2012, 08:09 PM
EOD Guy's Avatar
The actual switch bolts to the steering column, there should be a small amount of adjustment...... if you remove the switch you can insert a small screwdriver and slide the switch thru the start position and make sure it's the rod.....it might be the switch, or the Netural Safety Switch, or the purple wire from the NSS to the "S" terminal on the starter
will a 80's starter work in a 70's chevelle R5 CHEV WAGON Electrical 2 06-26-2012 03:28 PM
Brake Push Rod Adjustment jor Suspension - Brakes - Steering 4 12-05-2007 06:23 PM
Rochester Metering Rod Adjustment Help Please TRUCKINCHATTY Engine 5 02-05-2006 11:57 PM
where's my starter?? 69 chevelle malibu 307 malibuman Engine 6 10-30-2003 10:50 PM
Chevelle starter wiring Tom S Electrical 2 08-04-2003 08:41 PM
