71 chevrolet c10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2013, 08:20 AM
71 chevrolet c10
i have a 1971 Chevrolet c10 truck with a original inline 6 and a powerglide transmission does anyone no what kind of differential I would have since im thinking of putting a v8 and a turbo 350 trans in. thanks
Old 12-05-2013, 08:21 AM
big gear head's Avatar
High Performance Rear Ends
All of the '71 Chevy trucks had the 12 bolt rear end. Strength is not a problem.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (12-05-2013)
Old 12-05-2013, 04:01 PM
what gear would I have? thanks
Old 12-05-2013, 04:40 PM
Probably a 3.73 or 4.11 with the 6 cylinder. The only way to know for sure is to remove the cover and check.
Old 12-05-2013, 05:44 PM
Banned
pass side axle tube will have a code stamped in it..(front )
like this, this is from my 71, it's a 308 open
Old 12-06-2013, 09:33 AM
I installed a 12 bolt truck rearend(similar to the car rear, but smaller pinion bearing IIRC) it had the 8.875 8-7/8" ring gear. When I got stock it had 3.07 gears in it. It bolted right into my 84 Sierra, but I needed that non-stock pinion seal in order to use my 10 bolt yoke on it.
peace
Hog
fitting 1972 c10 brakes on a 1963 c10 hman17024 Suspension - Brakes - Steering 3 04-09-2013 08:20 AM
95 Chevrolet rearend in an 86 Chevrolet? kvsbmsdws Transmission - Rearend 1 01-03-2008 12:11 PM
Grandpa's 71' Chevrolet C10 2wd glayman Introduce Yourself 13 02-13-2007 09:18 PM
Looking for a 55 chevrolet Invader55 Introduce Yourself 3 09-26-2005 06:52 AM
1971 Chevrolet C10 Mowdigger General Rodding Tech 2 10-26-2004 05:33 PM
