71 Chevy 3/4 ton Locker - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2005, 07:20 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I have been trying to find a locker for an Eaton H072 rear axle under a 71 Chevy 3/4 ton. Does anybody know where I may be able to find such a unit?
Old 10-24-2005, 02:38 AM
tornado-tech's Avatar
No one make a locker for the Eaton anymore. You will have to find a used one since some 67-72 trucks came factory equipped with the Detroit Locker. Best try the junkyards or e-bay.
Old 10-24-2005, 06:41 PM
Blazin72's Avatar
Wiki Edits: 19
That isnt surprising given how old those axles are.
Old 10-24-2005, 07:03 PM
It may be cheaper for you to find a 10.5" 14-bolt rearend and do a rear axle swap instead of trying to find that 17-spline Eaton Detroit Locker. Even though the ring gear will be smaller, the axle spline count on the axles will hold more horsepower than then the Eaton and is much cheaper to build plus will have much more axle ratio's ratios available and the disc brake availibility is much easier and a lot cheaper. Good luck in whatever you decide.
Old 10-25-2005, 06:39 PM
Blazin72's Avatar
Wiki Edits: 19
It's my friends truck. He wants to keep the axle just because they arent very common. Didnt know those were 17 spline axles, they must be some monster splines. Do you know the ring gear diameter on the H072s and the axle diameters?
Old 10-25-2005, 07:56 PM
They have 12 1/4" ring gears and 1.55-diameter axle shafts. There were only two ratios of gears offered: 4.57 and 5.14.
Tach in 76 Chevy 1/2 Ton Phyrkrakr Interior 1 05-01-2003 04:34 AM
1992 chevy 1/2 ton (383 Stroker) won't rev! dunegoon Engine 2 12-10-2002 08:41 PM
48 Chevy 1/2 ton V8 engine placement tomy2tone01 Engine 3 12-09-2002 01:59 PM
89 chevy 1/2 ton step side johnsongrass1 Engine 0 09-09-2002 11:31 AM
Need 51 Chevy 1/2 ton bed oldford Body - Exterior 0 04-12-2002 08:01 PM
