71 chevy malibu 4dr L6 to V8 swap questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 10:59 PM
kougsmotors's Avatar
i plan to remove the 230 ci l6 from my 71 maliby 4 dr and replace it with a 350 small block v8. when i mount the new motor will it move the transmission forward or backward and therefore require an custom length driveshaft? how will i need to modify the throttle linkage to accept a 350 ( the new motor will have a holley carb) any helpfull advice will be appreciated.
Old 06-13-2010, 11:31 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I've never done this particular swap, so I don't know if the 6-banger trans is in the same place with the same mount as the V8 trans. At any rate, you shouldn't have to build a custom driveshaft. With all the V8 '71 Malibus there must be out there languishing in the boneyards, at least one of them must still have the driveshaft under it that you can buy. You should need no custom pieces to do this swap.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Buick V8 to Chevy trans Smonska Transmission - Rearend 7 04-12-2003 03:58 AM
rear end swap from a trans am to a chevy malibu bigslickwille Transmission - Rearend 3 12-20-2002 02:34 AM
1991 chevy 4wd V6 swap to V8 Michael Breaux Engine 3 10-20-2002 02:48 PM
pontiac V6 to chevy V8 swap snake Engine 2 01-20-2002 03:58 PM
