71 Chevy Rearends - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2006, 05:25 AM
71 Chevy Rearends
71 chevy 4x4 rear ends
Question? I have a 71 chevy pickup 4x4 with a dana 60 rear and a dana 44 front. Will a 4.10 rear gear work ok with a 4.09 Front gear. Normaly I no that you would want them the same, but i havent found any one that sells a 4.09 for a Dana 60.
Please help me.
JRD Modifications
OuT
Old 06-01-2006, 07:43 PM
Old Yeller 1970's Avatar
Loud Pipes Save Lives
If you don't get a response, the guys over here know a lot about trucks. Maybe someone there can help.
Old 06-01-2006, 11:08 PM
It will work just fine. The normal acceptable range is that they need to be within 1%.
4.10*.01=.04
So the front end could be from 4.06 to 4.14 and still work fine.
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
Good rearends for 71 Chevelle Meangreen Transmission - Rearend 5 06-22-2003 08:34 PM
Buick V8 to Chevy trans Smonska Transmission - Rearend 7 04-12-2003 03:58 AM
chevy 10 bolt rearends torgue specs fuman Transmission - Rearend 0 12-24-2002 10:26 AM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
