Hotrodders Bulletin Board
#1
71 el camino disc brake conversion
I want to put disc brakes on my 71 el camino. I can get them at the pick a part for super cheap; if I can find a suitable donor. S10s and Caprices are a dime a dozen, for example. My allignment shop says S10s use the wrong ball joints.
#2
re: 71 el camino disc brake conversion
All GM intermediates from 1964 to 1972 (Chevelle, El Camino, Skylark, Cutlass, Tempest, etc...Monte Carlo and Grand Prix 1970-72) use the same basic front suspension and hubs/brakes. There ar some slight variations in control arm bushings and tie rod end sizes.
Also Nova and Buick Apollo/Pontiac Ventura from 68-74 are the same, but you'll have to switch the bolt on steering arms side-for-side as they had the steering box behind the front wheels. Disk brakes were available from 1967 to 1972. Metric and S-10 will not fit, nor will 70-81 Camaro/Firebird. The 73-77 intermediates and 77 up full-size GM's use the same as the 70-81 Camaro. |
#3
Thanks. That is somewhat helpful. I already know all that except for the part about 77 full size. The question I asked was that I will ACCTUALLY FIND AT A JUNK YARD not what I can order for $500.oo out of a catalog.
#4
Chances are, you wont find a 67-72 Chevelle disk setup, still in a boneyard...........
Try these guys.......for brackets that bolt to your spindles... http://www.scarebird.com/6928.html 1964-72 GTO, 442, Chevelle, Skylark, GS, Cutlass, SS $105* |
#5
I've heard that doing that will screw up your steering geometry (bump steer, I think). Your original steering arms will work just fine in their original positions, since your Elky & those Novas use the same spindle. '67-'69 Camaro/Firebird also use the same parts. |
#6
As others have noted, you will ACTUALLY FIND pretty much nothing of use in a wrecking yard. The A-body and 1st gen F-body people have picked those clean. GM changed ball joint stud taper in the early 70s when they did major model changes, so spindles from the 73-up A-body, the 70-up F-body, the 71-up full size, and the 75-up X-body (Nova et al) will not fit. Same for anything later like G-bodies or S-10s. You probably already know about the B-body tall spindle swap onto 64-72 A-bodies, so I wouldn't want to bore you. That requires expensive upper control arms. The low-cost alternative is to have your drum spindles redrilled for the original style disc brake brackets. The upper bolt is different. You can get repro caliper brackets for around $40 a pair on ebay. The rotors and calipers are available at any auto parts store. |
Back to top |
Similar Threads for: "71 el camino disc brake conversion"
| 79 El Camino Rear Disc brake conversion | Nailhead | Suspension - Brakes - Steering | 3 | 04-06-2007 04:32 PM |
| 1964 F100 Disc Brake Conversion | Charlse P. Green | Suspension - Brakes - Steering | 5 | 01-14-2007 09:09 PM |
| disc brake conversion for 65 rambler | 65ramblinwreck | Suspension - Brakes - Steering | 3 | 12-21-2006 06:22 AM |
| Ford Galaxie Disc Brake Conversion | CrashFarmer2 | Suspension - Brakes - Steering | 2 | 12-07-2004 11:35 AM |
| `33 Ford disc brake conversion | Mike Humphrey | Suspension - Brakes - Steering | 0 | 02-17-2002 02:49 PM |
