71 Impala Rear End Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2011, 09:01 AM
I recently purchased a 1971 Impala Sports Coupe. I am not aware of the gearing in the gear end but I know it's not posi so it's not what I want. I'm sitting a SBC 409 under the hood with a 35o Trans and 3500 Stall Converter. But basically I would like to know what rear ends would sit right in the impala without to much modification. Would appreciate any advice. Thanks.
Old 11-14-2011, 02:58 PM
SSedan64's Avatar
What Rear is in the car now? 12-Bolt, 10-Bolt?
Old 11-14-2011, 04:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you have the 8.5" corporate rear end (IIRC you should- well, that or the rarer 12-bolt), keep it and swap out the carrier for an Eaton and a pair of 30 spline Strange or Moser axles. Yukon gears have had good reviews (I've never used them), or whatever brand you prefer. That's enough to keep up w/most anything you're likely to put to it unless you go to a trans brake and/or slicks a on a prepped track.
Old 11-15-2011, 07:22 AM
Thanks Cobalt.. I was just making sure there wasn't a big body with a good rear end like the Monte Carlo SS or Grand National in the G-Body Family. And the most racing that will be done will be street.
Old 11-15-2011, 07:23 AM
It currently has a 12-Bolt
Old 11-15-2011, 09:04 AM
TroyBoy's Avatar
Psychomotors
You could check out a Lock-Rite. You take out the guts of your single track carrier and put this in its place. Providing you have a good gear ratio already installed from the factory, I would get a good set of axles like suggested above and have some fun.
Advanced Design Rear end swap with impala? shep2 Transmission - Rearend 6 02-14-2011 04:11 PM
63 impala trans swap joeyb Transmission - Rearend 2 06-06-2010 02:44 PM
62 Impala LS1-6 swap Dragwagon62 General Rodding Tech 3 12-27-2009 02:54 AM
62 Impala LS1-6 swap Dragwagon62 Engine 0 12-23-2009 10:16 AM
swap 283 to 327 impala 1967 ricolala Engine 11 03-03-2009 11:28 AM
