71 nova power steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2008, 05:43 PM
schetk's Avatar
I am building a steet rod with a 71 nova rear steer set up. I put a new pump on and and started my newly rebuilt 350, when the engine started for the first time the wheels turned all the way to the left and locked up. What did I do wrong? I have not got under the car yet to see where or if I disconnect the pitman arm to see if the wheels will turn back straight.
Old 03-29-2008, 11:20 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
The wheels turned left all by them self?
Old 03-29-2008, 11:58 AM
schetk's Avatar
Yes, once I started the car. I have a 70 nova subframe that came with the steering gear. This sat outside for a number of years and maybe the valves inside froze up? all the lines were hooked up correctly.
Old 03-29-2008, 01:01 PM
68NovaSS's Avatar
Wiki Edits: 9
Wow, did you say gee or haw when it started?
I'd disconnect the hoses and try to move them back, look for binding in the cross linkage or idler off the frame rail. As far as the 'auto turn' thing, now that's interesting, I know the pressure and return lines are different so not much chance you have them crossed.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 03-29-2008, 03:47 PM
weirdbeard's Avatar
1976 Ranchero GT
I have never heard of such a thing. I would have to guess the steering gear is full of junk or toast. I would also wonder about the new pump being contaminated now if that is the case..
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Headers hitting power steering box topdogger Engine 10 02-26-2007 09:48 PM
new power steering pump questions HARVICKx29 Suspension - Brakes - Steering 3 09-05-2005 03:22 PM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 10:15 AM
Power Steering Hose Connections Larry D Suspension - Brakes - Steering 3 12-02-2003 07:06 AM
