71 pontiac lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2010, 08:53 PM
71 pontiac lights
i am having problems getting my lights (headlights, taillights, brake lights, interior lights) to work on my 71 lemans. i finally traced it to not having power to the fuse box. long question short.. what color is the main power wire into the fuse box and where is it located?
Old 03-16-2010, 11:53 PM
sqzbox's Avatar
My pipes are my music
Indian heads
Pretty old stuff there. 1971, I had a few but can't remember if it connected to a junction or went through the firewall to the back of the fuse box.
Funny it's only effecting the lights. When did this problem start?
Old 03-17-2010, 11:05 AM
well i bought the car without a engine or tranny.. been having problems putting it together from day one.. got a good deal on an older crate goodwrench 350 with some goodies on it so i put that in there. i just wired the starter up so i can run it.. but now i am trying to get her road worthy..
Old 03-17-2010, 11:36 AM
sqzbox's Avatar
Might want to check and make sure there's a ground strap between the engine and the firewall and Neg. post to the body. Old saying is "no ground, no lights" Make sure before you start tearing into the fuse block, could save some time and trouble.
Old 03-17-2010, 11:48 AM
ericnova72's Avatar
More for Less Racer
Main power wire should be red, a big 8-10 ga wire, and either hooked to the battery post at the starter, or in the harness that comes across the front of the core support(with headlight, horn and signal wires) and hooked to the main battery post on the battery.
Old 03-20-2010, 04:04 PM
after hours of investiaging and tracing wires.. i find out its just a ground not hooked up. thanks for the help
Old 03-20-2010, 07:11 PM
sqzbox's Avatar
Grounds
Good deal! Glad you got it working. Have fun! And thanks for the update.
HELP!!! 200 pontiac Sunfire warning lights???? Dave57210 Electrical 5 03-04-2010 07:58 PM
Parking lights from Turn signal lights 32chevy vett Electrical 7 03-30-2007 06:46 AM
1972 Pontiac LeMans Brake Lights David Krogh Electrical 3 08-21-2006 02:26 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
No Reverse lights!!! 69CamaroRSVert Electrical 9 07-09-2003 04:23 PM
