71 rear differentials - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2010, 05:24 PM
how do i figure out what differentials i have its either limited-slip or open and i dont know how to find out or figure it out!?!?
Old 09-20-2010, 06:53 PM
big gear head's Avatar
High Performance Rear Ends
Well, you didn't say what you are working on, so I'm assuming that this is a '71 Chevy truck, probably a 12 bolt. Next time please tell us what you are working on. The ONLY way to tell what is in it is to remove the cover and look inside. I'm sure that someone is going to say that you can jack it up and spin the wheels, but this is very unreliable. Just remove the cover and look inside.
Eaton Posi
Eaton Governor Lock
Standard differential
Old 09-20-2010, 07:04 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
This is very true, You can jack them up all day long and spin the wheels but if something is wrong inside then you can be decived.JMO
Cole
Old 09-20-2010, 07:06 PM
ok thanks and im workin on a 69 step side with a 71 12 bolt and thanks
Rear Lower Control Arms, best choice? BUFFALOBILLPATRICK Suspension - Brakes - Steering 4 02-06-2009 12:43 PM
68 firebird to camaro rear seat 68birdman Interior 24 11-23-2007 11:07 PM
71 nova rear end. weld the axle housings or not? chevymastermind Transmission - Rearend 5 03-26-2007 08:39 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
Rear end from a 71 Cutlass medicdogg Transmission - Rearend 1 11-17-2002 01:59 AM
