Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 71 SBC 350 build question/opinions - also new - Hi
Old 04-23-2013, 11:42 AM
1badLemans's Avatar
1badLemans 1badLemans is offline
Your build seems on tack for a daily driver/tow. Make sure your carb is a vacuum secondary carb NOT a double pumper. Also I would just like to up the compression as it always increases power. Maybe a set of 62cc flow-tek heads from speedway motors which are also aluminum for $740 assembled. But all in all your heads and cam should make enough torque to make you happy. Good luck
