71 skylark front passenger control arm bushings installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2011, 12:53 PM
wiser626's Avatar
1971 Buick Skylark 350-4
I would like to know the difficulty of replacing the bushings from the control arm on a 71 skylark. will i need any special tools? steps would be appreciated if difficult. thanks!
Old 11-20-2011, 01:40 PM
LATECH's Avatar
The uppers are pretty easy, the lowers facilitate the need to remove the lower control arm.That means you will need to compress the coil spring and decompress it.
You can install them with a BFH and a junky socket that fits the metal shell of the bushing.
I just replaced mine this summer on the blue car here in the photo,I used a piece of 5/8 allthread for the spring compressor. I put it through the spot where the shock absorber lives (after removing the shock)and cranked the nuts down, once the tension was off, I removed the bolts and the arm.
After replacing, be sure to leave the through bolts loose ,like backed off one turn before they tighten,as when you tighten them you want to have the car setting on the tires so the bushings are positioned properly before tightening them down.Doing this ensures proper ride height, but more importantly,it keeps them loaded correctly when on the ground. Not doing this will twist the bushing when you do set it down,throwing off the ride height and twisting the bushing abnormally far, resulting in failure of said bushing.
Old 11-22-2011, 12:24 PM
wiser626's Avatar
the uppers are the only ones eaten up on my car. do i need to disassemble the control arm? when i bought the bushings they gave me 2 of em. i believe one for the bottom and one for the top. for the uppers do i still need to compress the spring. i just dont wanna spend the whole day on bushings. thanks alot!
Old 11-22-2011, 05:06 PM
LATECH's Avatar
You will need to pull the upper arm OFF of the car.It takes 2 bushings.
You should put a jackstand under the lower control arm and rest the weight of the car on it. Then seperate the arm from the car and install your goodies.
control arm bushings itsandre Suspension - Brakes - Steering 3 05-16-2011 07:09 PM
control arm bushings montea Suspension - Brakes - Steering 15 04-22-2007 08:06 PM
Help with Front Control Arm Bushings TheBreeze Suspension - Brakes - Steering 11 11-06-2005 10:04 PM
control arm bushings chevypunk Suspension - Brakes - Steering 5 10-30-2003 10:21 PM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 08:26 AM
