Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 71 truck 350 acting real strange
Old 04-24-2007, 10:01 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
You should check the timming & the plugs
then pull the valve covers & look for anything out of place or making noise.
also check the timing chain.
Remove cap then rock the crank {by hand} back & forth} to see how much play is in the chain by watching the dist cap {how much the crank turns before the dist does}
You might have a sticking valve or lifter in that case marvel Mystery oil.
R
"SlowRide66"
"Illegitimis non carborundum"
