72 C10 2wd Corvette suspension swap help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2009, 12:43 AM
Hello, sorry, new to forum. Has anybody run across a suspension swap that uses c4 aluminum front end stuff on the 67-72 c10 trucks? I've heard of the swap once on truckin web, and I'm interested on doing the same. Does anybody here have experience with such a swap? what is involved? I can fabricate pieces well if i need to, but i'd rather just find something that swaps in (i'm lazy, so shoot me). any help would be much appreciated.
Old 09-23-2009, 02:51 AM
SSedan64's Avatar
If anyone will know this is the site >> http://67-72chevytrucks.com/vboard/f...splay.php?f=25
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=3
Old 09-23-2009, 01:17 PM
I'm already a member of the site, but for some reason it won't let me post threads. thats why i asked here.
Old 09-24-2009, 02:40 AM
CMR CMR is offline
0.....55.../100
I'm not sure if this is a good idea or not. Remember a corvette probably weighs a lot less than that old steel bodied truck. You might be better off just getting some sway bar kits and better tires.
Old 09-24-2009, 05:16 PM
yeah... much heavier. but starting that generation the corvette was designed to be a world class car and handle around tracks going faster than my 72 will ever see. that puts tons of stress on front end components. i think it will be ok on a truck with a straight six going half that fast on the highway. plus, forged aluminum uprights and cast uppers and lowers means low unsprung mass. also much stiffer than stock flimsy stampings.
Old 09-24-2009, 08:01 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
C4 Corvettes are no lightweights by any means. You will have no problems with that suspension in your truck. I have installed both front and rear C4 suspensions into many vehicles with no issues regarding strength. While I have not installed a C4 front into a truck like yours, I have installed both a front and rear suspension into a 90's SS 454 pickup many years ago. This truck was built for a former IMSA and Indy car driver, and he drove it hard! That particular truck also received an HO 454 and a Turbo 400 so it was no lightweight. The only suspension modifications for that project were to upgrade the rear trailing arms and camber links, shocks, and the front composite spring, all else was stock. All the mods were just for more adjustablility, not due to strength issues. I did also install a custom adjustable rear anti-roll bar, but that isn't required, the stock unit will likely work just fine if you go that route.
There are no kits available that I am aware of for your application, but if you can fabricate, you can make it happen. And it is definitely worth the effort!
Shoot me an e-mail if you would like more specific info on the installation.
Andy
Old 09-24-2009, 08:08 PM
this is the link that really got me thinking...http://www.truckinweb.com/tech/suspe...ion/index.html .
Old 09-24-2009, 08:30 PM
Wiki Edits: 31
The C-10 suspension geometry is correct for a truck... my dad has a '72 LWB that is bone stock, 350/350, it might not be a slot car but, it handles pretty good for it's size.. even taking corners 70 MPH+ aside from being in a " white nuckle " state from the adrenalene, it holds the road just fine.. and it'll hold 100 MPH with no issue.. this isn't somthing that gets done all the time with it, or very often at all but it has been 'tested' ( Never raced )
Old 08-01-2010, 11:20 PM
ccreddell's Avatar
Porterbuilt makes a Dropmember that uses Corvette C4 suspension, and the geometry is slightly modified to work better with the truck weight and wheelbase.
http://porterbuiltstreetrods.com/site/
Hers a couple build links;
http://www.classictrucks.com/tech/07...ember_kit.html
http://www.google.com/custom?domains...FORID:1;&hl=en
Old 04-20-2011, 10:17 AM
How about the link :
www.flatout-engineering.com
Old 06-14-2011, 07:28 PM
GUITAR1989's Avatar
Guitars & Cars >8D
I got a poste together with all those links then scrolled down to see that you guys allready beat me to the punch All are verry cool systems...porterbuilt would be my first choice. They are actually making a dropmember that you can use coilovers with
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Mustang II Suspension swap? bonuts Suspension - Brakes - Steering 8 01-10-2006 07:13 PM
1970 c10 i6 to v8 swap, how hard? chr15 Engine 2 08-06-2005 07:27 AM
70 c10 suspension swaps 70chevyc10 Suspension - Brakes - Steering 13 05-09-2005 07:21 PM
'72 to '70 EC Swap. MI2600 Body - Exterior 2 01-16-2005 02:26 PM
72 C10 - 307 vs 283 - Need Torque icegnome Engine 5 12-03-2002 09:43 AM
