72 C10 Gas Tank Retrofit - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2010, 11:11 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Hey guys has anyone done a gas tank relocate on a 67-72 C10 pickup mine is a 72 , I want to get my tank out of the cab and install a new one in chassis, wanted to buy a good kit and maybe pick up some tips for doing it right, there are a few kits to choose from or maybe a another chevy/gmc truck tank would work?
Thanks
Old 08-22-2010, 11:55 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you go with the suburban tank for those years you can wind up with a factory installation..might be easier than re-inventing the wheel..
Sam
Old 08-22-2010, 03:00 PM
sbc307's Avatar
I bought the the kit from lmc truck it was like $200 plus shipping, came with new 21 gallon tank, straps, new sending unit... If fits right where the spare tire use to go. You have to grind the rivets off the support the old tire up, get that piece out of there, then put tank up with a jack see where ur straps line up drill holes bolt the one end up and the other they give you J-bolts, extend the gasline back and sending unit wire, hook that up and mount tank.... then where the fill up neck is on tank you have to notch the frame out and basically put ur fill spot anywhere in the bed you want..... Its pretty simple just take your time and you'll be fine. Also if you go on my profile under my pics, there a pic of the rear of my truck, you can see part of the tank and the fuel fill up in the bed. sbc307
Old 08-22-2010, 03:01 PM
Sinister's Avatar
A lot of guys use Blazer tanks. You still have to fab up a fuel fill though. I've seen fuel fills in stake pockets, side markers, tail lights and the bed. You should check out: http://67-72chevytrucks.com/
Old 08-24-2010, 11:37 AM
Custom10's Avatar
Thanks guys, good info
Old 11-28-2014, 10:17 PM
great info
Old 11-28-2014, 11:10 PM
Blazer tanks sit a bit low if this is something that will have the grass against the rockers kind of deal.
Here is a thread that shows a "low profile" tank in from a 50's Chevy car.
Farmers big block - The 1947 - Present Chevrolet & GMC Truck Message Board Network
gas tank construction anglia48 General Rodding Tech 4 02-11-2005 02:17 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 12:26 PM
gas tank 4 72 impala miamipoloboyz General Rodding Tech 1 10-06-2003 04:58 AM
gas tank for a 72 impala... miamipoloboyz Engine 2 10-06-2003 03:35 AM
aluminum gas tank crazy larry Hotrodders' Lounge 5 01-07-2003 02:44 PM
