72 camaro nose on a 78 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2006, 02:51 PM
roy383ci's Avatar
hi
i bought a complete front nose and fenders
from a 72 camaro ,and want to build it on my 78 camaro.
here comes the problem the radiator support from the
72 nose is complete rotten and takes me a few day to rebuild
but can i use the 78 rad support or is it a bit differend
a radiator support in the npd catolog goes from 1970 to 1973
and there is no more info over other rad supports 1974/1981
thanks
Old 02-25-2006, 05:06 PM
Wiki Edits: 31
check with classic industries, they deal with the '74-'81's and the earlier 1's. is there anything left of the rad support? if so, just match it up.
Old 02-25-2006, 05:38 PM
I put a 71 Spit bumper RS front clip on a 79 camaro RS years ago but used the whole assembly. It was an easy swap from what I remember. Bob
Old 02-25-2006, 05:59 PM
www.nastyz28.com - Second generation camaro experts there.
72 camaro subframe in my 72 nova 396nova Suspension - Brakes - Steering 4 07-09-2011 04:58 AM
Can I make my 78 firebird into a Camaro? Suckingas Body - Exterior 9 06-28-2010 11:06 PM
forth generation camaro nose swap squeak3876 Body - Exterior 1 06-24-2004 06:57 PM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 02:51 PM
78 camaro suspension andybird Suspension - Brakes - Steering 7 07-14-2003 04:43 AM
