72 Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2010, 04:56 PM
Zee Zee is offline
72 Chevelle
I have recently received and installed a horn relay on my 72 malibu, I would like to know if the green wire goes on the top post, and what is the black wire (I assume lower post). I know that the green wire is the horn. Besides the horn relay and the green horn ring what else could be missing/wrong, as the horn will still not blow. It has an after market grant wheel and everything is ok with the horn mech. Any sugestions.. There are a million threads on 72 horn probs, but none have helped me. If I short the green wire it blows
Old 12-12-2010, 06:13 PM
EOD Guy's Avatar
Narrow it down, if the horn blows with a direct jumper to hot, try bypassing the horn relay, jump the relay if the horn blows - move to the firewall wire, bypass it etc... if at any stage the bypass/jumper fails to make the horn blow that's the bad part/wire etc...
Old 12-12-2010, 06:46 PM
Zee Zee is offline
Good news
I just went out in the cold 1 last time, and what it ended up being was the grant steering wheel paint would not let the contact point ground against metal, so I scraped the paint at the points. I just wonder how many of the horn probs I read about could be from this..Thanks for the replies.GZ
NEWBIES 1st POST 72 chevelle spindles MII 42CHEVCOUPE Suspension - Brakes - Steering 3 01-04-2008 07:49 PM
Seats for 72 Chevelle projectjohn Interior 2 03-06-2006 01:20 PM
72 chevelle rear ends 406chevelle Transmission - Rearend 10 02-15-2004 10:22 PM
72 chevelle 2wld4u Suspension - Brakes - Steering 1 07-22-2003 05:30 PM
will the rear end out of a '65 chevelle fit a '72 Snatch Transmission - Rearend 3 03-02-2003 05:15 PM
